Results 1 to 10 of 127
Thread: The Magna Headlamp FAQ:
    Jun 2012
    Hi All, blew the drivers side low beam globe in my TF exec the other day and used the opportunity to order a set of Philips X-Treme Vision H4's which arrived today. Drivers side replacement looks pretty straight forward by removing the washer bottle, but the passenger side is going to be a bit more complicated, as by reading back a few pages on this thread (also confirmed by a quick look under the bonnet), the battery and fuse box need to come out.
    My concern is the last time I replaced the battery myself, I left in disconnected too long and the engine management computer re-set itself and had to go to Mitsi's to get it set up again along with a throttle body clean, which I want to avoid doing again.
    My question is, what's the best method to maintain voltage to the computer, whilst removing the battery to change the headlight globe?
    Thanks for any help you can provide.
    Yes, its a Mitsi! vlad's Avatar
    Jun 2003
    Quote Originally Posted by rakhurst View Post
    I did mine by moving the fuse box out of the way and disconnecting the battery. Should only take a few minutes. Can always use a spare battery to run to the cables. That is, connect +ve from spare battery to the +ve lead in the car and connect the -ve from the spare battery either to the -ve lead in the car or engine block. You then disconnect and remove the battery. If you don't have a spare 12V battery then two 6V batteries in series (ones used for lanterns) will do.
    Jun 2012
    Cheers for that Vlad. Good advice. Just got to see if my jumper leads will reach across from the missus' car.
    Administrator Red Valdez's Avatar
    Jan 2006
    You can perform the learning procedure yourself. The guide is here.
    Otherwise, your automatic transmission will resume usual shifting after a week or two's worth of driving. You'll get an ocassional flared gear change but nothing to worry about.
    At the end of the day though there's no need to go back to the dealer for it.
    Current Ride: 2018 Pajero Sport GLS
    Former Rides: 2007 380 SX | 1997 NL Pajero GLS | 2005 380 GT
    The one that started it all: 2001 TJ Magna VR-X
    Voted AMC /// /// QMD Best Overall Car 2011
    Jun 2012
    I've got the 5 speed manual trans in mine. The problem I had after the battery disconnect, was engine simple wouldn't idle. Drove it to work and back (hour each way in heavy traffic) next day and went nearly insane where it would stall nearly every time I had to stop. Never did get the hang of heal and toe manoeuvre
    I guess if I persisted and drove it for long enough, it would self learn.
    KWAWD's Avatar
    May 2012
    Couldn't you access the lamp via the wheel bay? Removing the plastic guard thing?
